588,500 active members*
5,485 visitors online*
Results 1 to 6 of 6
    Oct 2005
    124
    Longer X-axis On Taig
    I have a Taig 2019 CNC mill. Does anyone have a suggestion for getting more x-axis travel out of this machine? I'd like to go up to 2 feet. Right now, I have about 12" of x-axis travel. I realize that I would have to build a new table for the mill. Has anyone done this before?
    Gary Shepherd
    www.16tracks.com
    Oct 2004
    168
    It really wouldn't work well, you don't have enough bearing surface to support a cantilevered slide that long.
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
    Oct 2005
    124
    I wouldn't be loading it down with 300 lb chunks of steel.
    Gary Shepherd
    www.16tracks.com
    Sep 2006
    1738
    I don't really see this, anything is possible, but I'm not sure if it's worth getting the extra 12 inches of travel, and that is really pushing it.
    -Jason
    Nov 2006
    1036
    I have a Sherline not a Taig but I think this is relevant. I bought the extended X axis from A2ZCNC some time ago. While it is well made and works well, it does bind at the extremes of right and left travel. I would imagine that binding would be a big problem if a Taig was extended 12 inches.
    Oct 2004
    168
    Here's the thing. Say you have a 30" table, which allows you to have it fully engaged by the gibs at the extreme of 24" travel. If the table at the furthest extent is pulling down with one lb of force, it's exerting a 5 lb upforce on the gib. So if the stepper weighs one pound, and the table weighs a couple of pounds (it gets more complex because the load is distributed along the beam, but let's keep everything simple), you would have lots of force pushing the slide against the gibs. Add vises, the weight of the workpiece, etc and it really causes a lot of force on the slide. The fulcrom is the edge of the x axis where the slide enters the carriage.
    F1D1 = F2D2 is the equation you need to use in figuring this out.
    Nick Carter
    www.cartertools.com
  1. Taig Z Axis
    By djh82uk in forum Taig Mills / Lathes
    Last Post: 09-08-2007, 01:37 AM
  2. Trying to set up Taig 4-axis with EMC2
    By nickydubs in forum Taig Mills / Lathes
    Last Post: 02-14-2007, 02:31 AM
  3. Taig 4th axis setup
    By gabi68 in forum Mach Mill
    Last Post: 01-11-2007, 06:02 AM
  4. Taig 4th Axis Concept
    By nattyone960 in forum Taig Mills / Lathes
    Last Post: 11-17-2006, 10:02 AM
  5. BP Ser 1 , Ez Trak: Axis Readouts suddenly no longer accurate
    By XRM37 in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2005, 05:04 AM
