587,999 active members*
2,735 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Changing Direction of Internal Taper
Results 1 to 6 of 6
    Sep 2009
    12
    Exclamation Changing Direction of Internal Taper
    Hi There,
    I am very new to this forum so please forgive me in advance for any newbie mistakes.
    I'm using the controller on the TL-1 to make an internal taper. I want to reverse the direction of the taper so that the bigger diameter is nearer to the chuck and the smaller diameter nearer to the toolpost. The tool I'm using as well as the diameters of the taper allow enough clearance to do so. But for some reason I'm having problems reversing it. Any help with respect to the G-code needed will be appreciated.
    Sep 2007
    56
    Taper
    Are you using canned cycle to do this?
    If so...haas has wierd ways when you want to do non standard
    cycles. One way to fix this is to put it into Type II fanuc roughing.
    (I think thats what its called...going off of memory here)
    If you have manual, look under G71 and it has an explanation
    of type I and type II roughing.
    G'day
    Sep 2009
    12
    Hi Swain,
    Thanks for your help.
    I've had a crack at your suggestion but haven't been successful. I'm not quite sure what I'm doing wrong.
    I changed to Setting 33 to YASNAC and inserted R1 at the end of my G71 block to allow me to go either way in the x-axis. This is what the book said.
    Have you done this before, if so do you have a sample of your G code with particular attention to the G71 block?
    Any further help would be greatly appreciated.
    Thanks Again.
    Sep 2007
    56
    G71
    I have never set the machine to Yasnac...
    I left my machine as it came from factory and used the Fanuc setting.
    From the lathe handbook...
    "Type II, when Setting 33 is set to FANUC, must have a reference move, in both the X and Z axis, in the block
    specified by P."
    What this means....in your first block after the G71 cycle that has an X or Z move...add the other axis to it. For example,
    G96 S1000 M03
    X1.25 Z.125 M08
    G71 P100 Q101 U.04 W.01 D.05 F.008
    N100 G00 X-.062
    G01 Z0 F.004
    X.6125
    Z-.25
    N101 X1.25
    The line that has the N100 is the only line that changes. To make the program do Type II roughing change that line to this....
    N100 G00 X-.062 Z0
    The rest of the programming can stay the same...and hass will not error when you command it to do the inverse taper move or any other unless programmed to go past the starting location.
    Give it a try...!
    G'day
    Sep 2009
    12
    Hi Swain,
    Just wanted to say thanks for the help. The advice you gave me worked. All the best to you and your family for the Christmas Season.
    Thanks Again,
    Sep 2007
    56
    Quote Originally Posted by dlall View Post
    Hi Swain,
    Thanks Again,
    Most welcome...
    Merry Xmas to you and yours!! :cheers:
    Swain
  1. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  2. Replies: 2
    Last Post: 12-06-2008, 03:10 AM
  3. Help Please:- Stepper Not Changing Direction
    By audioandy1762 in forum CNC Machine Related Electronics
    Last Post: 11-07-2007, 11:15 PM
  4. motor changing direction by iteself using picstep
    By oliverthepig in forum CNC Machine Related Electronics
    Last Post: 04-30-2007, 10:11 AM
  5. M97 Internal Subprograms?????
    By CAMCRASH in forum G-Code Programing
    Last Post: 03-24-2005, 07:10 PM
