Originally Posted by
TarHeelTom
There is a power switch on the controller box, and a power switch on the spindle motor, and a power switch on the outlet strip everything is plugged into. This is apparently adequate for a small benchtop machine. For instance, the mechanical travel stops will stall the steppers on a Sherline.
The same would not be adequate for a larger mill. The Bridgeport I'm currently reworking had an eStop button with the original BOSS computer, and will have the same eStop button, at a minimum, after I finish configuring it to run on a PC. In addition, power to the computer and drivers comes through an air conditioning contactor, and power to the VFD for the spindle comes through a second air conditioning contactor. I've got a convenient wall switch which will kill the 24 volts to the contactors, which will make the mill get real quiet, real quick.
Tom
