I have a colchester cnc lathe Model - cnc-2000L having Fanuc OT-Model A(Software Version 602-06) with 2 axis servo motors with absolute encoders. I am facing following problems.
-- Work shift is not effective while I tried to chage it's value. I can input the value but it won't be effective.
-- I could not able to input Mx & Mz value.
-- I could not see the program directory.
-- I could not see it's ladder.
-- It's interface is quite different from OT-C.
-- As this machine having 2mtr.long bed with tail stock, If I try to make a small length component then I have to reenter the whole tool offset. While I tried to run from 2nd ref. point using G30. If i try to run the machine from 2nd ref. G30 instead of ref. G28,tool offset will change It will take additional value from 2nd ref. ( whatever I have enter in 2nd ref. parameter, It will addition to offset.) since work shift is not working,so I cannot compensate tool offset while using 2nd ref. G30 instead of using G28.
Kindly help me to solve these problems. If somebody have same cnc system OT-A having better version software ROM's them please let me know.
Someone told me that use G50 instead of G28, G30. Is it work for my problem.
I would much appreciate for help me out from these problems.
