588,444 active members*
5,139 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Vertical CNC Router - Like a Panel Saw configuration???
Results 1 to 10 of 10
    Jul 2009
    4
    I have this thought...what if you build a CNC router that is configured more like a vertical panel saw instead of like a table. You know...angled at like 75 degrees and snugged up to the wall. A 4' x 8' sure would take up a lot less floor space. What kind of issues would you run into? Gravity is not necessarily your friend any longer. I don't see it having a huge affect on your x-axis. You may want to rotate or modify your bearing system a bit. I also don't see it having a huge affect on your z-axis. Your y-axis is now going up and down hill. That could be a big deal, but I'm not sure. You might even be able to come up with a way to counter weight it, or give it pre loaded springs like a garage door. Has anybody seen anyone build one like this before? Anyone know of a commercial maching that works like this?
    Randy
    Mar 2009
    106
    May 2005
    55
    I did look into this configuration for my cnc router that i am currently building. I think the gravity issues as they pertain to the drive mechanics could be solved using a counter weight as you mentioned, or just finer drive gearing to prevent the tool from falling during power down. I found that the largest shortcoming of this design for me was that when machining pieces that would be cut free you would always have the problem of the piece falling on the bit and ruining the work. With some extra care in your gcode you could try to insure that the cutter finished on the top of the piece; however, this would be quite annoying. If you went with this design i would be prepared to incorporate a vacuum holding system.
    Feb 2015
    Re: Vertical CNC Router - Like a Panel Saw configuration???
    Hello there
    check this out… CNC Machining Centres | Casadei Industria
    Cheers Antonio
    Feb 2015
    22
    Quote Originally Posted by coop2005 View Post
    Thats what tabs are for. to prevent the piece from moving after a majority of the profile has been cut.
    Feb 2015
    22
    Entirely doable. The trick is to not go 90 degrees and have slightly less than gantry weight as counter weight so when the machine is powered down the gantry lowers slowly.
    Two pulleys, steel braided cable, and some pvc weight containment tubes and your on your way.
    Jan 2007
    1795
    it doable..
    however beyond full sheets parting up.. just makes life hard..
    but for that reason, working always with full sheets, very handy..
    a lot simpler to load than any other type router..
    Oct 2015
    An important benefit could be that much of the swarf fall down in the bottom of the cnc table. so cleaning the bed for new job installation would be much easier.
    May 2005
    3920
    It really depends upon your intentions as ti viability. If you have a very specific type of sheet goods machining to do such a router might be OK. Otherwise if you are expecting a versatile machine that you can throw a variety of jobs at I'd say forget it.
    If space is an issue you might want to consider a fold up router. This isn't an impossible idea and frankly probably would no save a great deal of space.
    Jun 2012
    817
  1. CNC Router Machine Configuration
    By cutleader in forum CutLeader
    Last Post: 05-24-2014, 02:04 PM
  2. Flexicam Router Configuration
    By procolores in forum Commercial CNC Wood Routers
    Last Post: 05-09-2014, 01:58 PM
  3. Vertical Bed CNC Router
    By SimplyDifferent in forum DIY CNC Router Table Machines
    Last Post: 11-29-2011, 06:01 PM
  4. Electrical Panel & Router Wiring Diagrams
    By Santa Fe Al in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 01:51 AM
