587,789 active members*
4,452 visitors online*
    Dec 2010
    DB9 shielding wiring
    I know that this question has been answered numerous times but I always find it a little bit cryptic and whilst I believe that I understand the theory behind it I'm wondering if someone can give me a fool proof way to wire up my shielding because I am getting a lot of noise
    I have a G540 connected up as instructed to a 48V power supply Ports 10, 11 & 12. Nothing else just that.
    My motors have a shielded cable running about 4 foot long and I have wired them as per Gecko's instructions
    6-9 for the motors
    1 & 5 with the resistance
    2,3,4 I have welded the shielding to.
    My motors are making a medium to high pitched buzz at idle and not amount of trimpot "tuning" makes it stop so I'm assuming it's noise.
    What do I need to do?
    Do I need to "earth" the shielding to the mains earth?
    Do I need to "ground" the shielding to the negative side of the 48VDC
    I have read and re-read through all the answers but can't seem to figure out what I need to do.
    Thanks in advance for any assistance
    Andrew
    You didn't ground the shield at both ends, did you?
    Dec 2010
    Quote Originally Posted by S3MIH3MI View Post
    No just at the G540 end
  1. Grounding/shielding questions
    By dfro in forum CNC Machine Related Electronics
    Last Post: 10-14-2008, 09:01 PM
  2. EMI shielding
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 02-29-2008, 03:18 PM
  3. Use of shielding gas on wood....
    By sntlewis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2007, 10:06 PM
  4. Connection of shielding
    By cncuser1 in forum CNC Machine Related Electronics
    Last Post: 06-18-2006, 01:57 AM
  5. RF shielding against plasma
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 11-18-2004, 04:36 PM
