Well, I started a build finally. Years ago, I bought the electronics for a different plan and never got around to building it. It was rather complicated with tapping and fabricating parts out of delrin, etc.
After quite a bit of research, I settled on the Solsylva 10x9 as my first build. I figure this can help me "cut my teeth" and possibly help me build parts for a future machine. I decided to do an "upgraded build" and use Oak and the higher end hardware.
I am progressing through the build nicely...have the base done and am getting ready to install the Y lead screw. And here comes my first question.
I have decided to do the Precision Acme leadscrew upgrade. I got the lead screw (3/8"-10 Sz, 1/5" Travel/Turn, 2 Starts) from McMaster Carr and the anti-backlash nuts from dumpster CNC. I am now looking at the plans and modifications a little more closely and am wondering....
I see how the screw attaches to the stepper through two skate bearings (Yes, I got the bigger size for this). In the design, when using all thread, you drill the hole on the opposite end just big enough for the rod...I would guess that this provides some support. But on the Solsylva website, they say you can actually make that hole much bigger and not have to worry about it.
My question is this...what provides support for the opposite end of the rod? Does it need support? Does the bearings and leadnuts provide enough support? Does the extra torque of the screw on the leadnut/bearings when the table is moved to the end closest to the bearings put extra strain on the parts?
Anyways...I guess it would be really hard to get another bearing lined up perfectly on the opposite side...but would that be optimal?
I'll post pictures of my progress in the next day or so.
Regards,
PiperPilot
