588,150 active members*
5,684 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Error 509 arc lack intersection
    Feb 2006
    123
    Control is a Centurion 1. This is strange, "The alarm 509 Arc lacks intersection" looks like a small gap in the run on the graph.
    When looking at the dot moving along you can see several blocks ahead and there is a small gap and that's were it stops.
    I have checked, run, verified and watched it machine the part in solid with my Bobcad, yet it stops on the Milltronics. It did two pockets and a hole with no problems then stopped on the third pocket.
    I am new with milltronics and Bobcad, now I know if I have a break in my bobcad I can't chain it together and I can't select my geometry.
    Ray.
    Aug 2005
    16
    Smile intersection problem
    Milltronics sometimes has a problem when two lines or circles intersect at a real sharp point, try putting a .010 -.020 rad. at the spot you are having a problem, this works some times.
    I have run milltronics control for a number of years and have had the best luck running the Conversational programs the are so much easier to run once you get the hang of it
    hope this works for you L.L.
    Feb 2006
    123
    Thanks for the quick response LL. The problem is I generate the program with Bobcad so I can't add any extra stuff, it was what it is.
    Ray.
  1. Babbit damage due to lack of lubrication
    By vger in forum Linear and Rotary Motion
    Last Post: 08-05-2009, 04:52 PM
  2. Lack of Vacuum
    By Donny Strange in forum DIY CNC Router Table Machines
    Last Post: 07-15-2009, 05:05 PM
  3. The Lack Of The One Program To Do It All And Do It Right
    By berin in forum OpenSource Software
    Last Post: 01-15-2007, 07:15 AM
  4. Complete Lack of Experience
    By rcazwillis in forum MetalWork Discussion
    Last Post: 12-05-2005, 03:48 AM
  5. PICStep and the lack of updates!
    By Garfield2 in forum CNC Machine Related Electronics
    Last Post: 05-21-2005, 11:00 AM
