Hi All,
I am new to this forum, looks like you all have a good healthy discussion of just about all realms of hobby CNC. A little background I believe is in order. I was retired 12 years ago from a major aerospace manufacturer after a transplant. Prior to that, I was a tool and die maker with a little CNC production time. My last 10 years were spent in Q.C. and test engineering. I have a small home machine shop consisting of a Bridgeport mill circa 1955 with a step-belt “J” head and a Clausing/Atlas 12” metal lathe. The shop has collected dust and rust more often than not in recent years due to health concerns and other projects/obligations. In 1997 I built a small point to point almost CNC machine controlled by a simple basic program to drill holes in pc boards. This was my last major shop project. It is constructed totally of aluminum with ¼”-20 lead screws and tin can steppers. I used ½” drill rod as ways and the aluminum table was the bearing. I have a pic of it if interested. Its capacity is about 6” X 8” and uses a dremel drill press for its Z axis. Its time for me to move on and I would like to build a larger, but still small router table that would fit on a tabletop. I had in mind a machine that would be from 30” X 30” to 30” X 36” in its external dimensions with a work capacity of up to 24” Sq. I have a roto-zip and a 1 HP craftsman router that I would like to drive with it. I want to do lettering, complex cutouts and 3D contour work with it.
In this long winded post, I guess my first question is, can this be built without using ball screws and expensive rails and still accomplish what I wish to do with it? I believe I can and I know I have the shop skills to get it done, but having not built one of these at this level, am I asking too much? TIA.
