588,484 active members*
5,391 visitors online*
    Nov 2007
    69
    metric thread
    just noticed on our HAAS tm1 when using VQC, that it wont accept a metric thread pitch! wtf!
    i answered all the questions, typed in 0.8 pitch for a 5mm thread, sent to mdi, run, stuffed the job!
    checked the code it produced, S500 @ F500. - should be F400.
    offsider then tried, we found that it wont accept the decimal point. .8 = 0 , 0.8 = 0 , 1 = 1 , 1.5 = 1
    any thoughts on this, or do i just have to edit the VQC code after its written?
    this is on a metric machine, or is it just that the VQC prog is written for imperial machines?
    thanks
    Nov 2007
    69
    rep changed the prog to a metric version
    all good now
    Dec 2008
    5
    nevermind
    Mar 2010
    suggestion,
    check default to float (setting 162) is in the on position
  1. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  2. Equivalent Thread Chart - Inch to Metric
    By twocik in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2009, 03:43 AM
  3. Metric Thread On LM8x14
    By pzzamakr1980 in forum Mini Lathe
    Last Post: 06-04-2008, 02:02 PM
  4. metric thread cutting
    By toolmaker_79 in forum G-Code Programing
    Last Post: 09-03-2007, 12:11 PM
  5. Metric thread form tap, drill chart
    By conceptmachinin in forum MetalWork Discussion
    Last Post: 08-27-2007, 10:31 AM
