588,195 active members*
5,095 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18i-TB Memory Card Only Inputs, Not Outputs
    Aug 2021
    4
    We have a 2005 Daewoo Puma 2000LSY with Fanuc 18i-TB control. We are attempting to transfer files between the CNC and PC via 64MB compact flash card + adapter.
    We have been able to transfer files from the PC to the memory card and then from the memory card to the CNC, but when we try to output programs from the CNC to the memory card, it gives alarm "086 - DR SIGNAL OFF".
    I believe this is because it is still attempting to output to the serial instead of the memory card, but we have not been able to fix this. Under "Setting [HANDY]" we are set to I/O Channel 4 for the memory card.
    Any help would be appreciated, thank you.
    Aug 2019
    145
    Re: Fanuc 18i-TB Memory Card Only Inputs, Not Outputs
    Sounds like parameters. 110.0 enables independent setting for input/output and could explain why you can input but not output to the card slot. You can either change that to use common setting for I/O or configure the appropriate parameters for separate I/O.
    Aug 2021
    4
    Quote Originally Posted by oetkbyentc View Post
    Changed 110.0 from 1 to 0 and it now works without an issue! Thank you so much, you deserve a raise
  1. Replies: 2
    Last Post: 08-22-2023, 07:52 PM
  2. Replies: 4
    Last Post: 04-17-2014, 10:50 PM
  3. GE Fanuc 18i-MB: Memory Card Error 0030
    By andyinwi in forum Fanuc
    Last Post: 05-16-2010, 12:12 PM
  4. Need Help please with Inputs and Outputs
    By MMT in forum Mach Software (ArtSoft software)
    Last Post: 01-30-2010, 12:57 PM
  5. inputs outputs
    By sintratech in forum Machines running Mach Software
    Last Post: 04-01-2007, 08:17 PM
