587,189 active members*
2,816 visitors online*
    Jun 2008
    20
    4 buttons not working on control panel
    Hello,
    Can anyone suggest some things I can try as a work around or to fix?
    I have a control panel on a Shenhui laser and 4 of the buttons aren't working (next to each other on the left side) all of the other buttons beep and change menu's etc.
    The buttons are those raised dimple type ones Attachment 222330
    Regards
    Rosco
    Jan 2008
    940
    Have you tried to reload you parameters.
    thunderlaser Guest
    Hi Rosco
    I think that probably you will need to replace the mask of the control panel,
    It would be broken, even if you could re-adjust all the buttons to back work, but it will soon is broken.
    Nov 2009
    314
    Hi ,
    This panel might be broken need to fix or change a new one in this condition .
    Regards,
    Ms.Mary
  1. Replies: 7
    Last Post: 01-10-2024, 10:14 PM
  2. Screen4 buttons not working
    By gort in forum Mach Software (ArtSoft software)
    Last Post: 03-10-2013, 11:51 PM
  3. buttons on osp 7000l panel
    By trois in forum Okuma
    Last Post: 01-12-2012, 12:19 PM
  4. Interact / TNC145 buttons not working
    By Mike Woo in forum Bridgeport / Hardinge Mills
    Last Post: 04-29-2009, 01:29 PM
