Originally Posted by
binfordw
Well I have tried from very fast to very slow, both in feedrates and acceleration values, and the results seem to stay constant.
Also, Ive checked X,A and Y motors now and all 3 seem identical in how they react. This explains why my gantry was going cock-eyed on my, since A run in reverse as a slave to X, the error is reversed.
As far as shielding, Im not sure. It is a Bladerunner kit, so it was all pre-wired. It does state clearly on the case "no shielding required".
It doesnt seem random at all, I havent checked for exact amounts of error, as in, how far off after a set amount of moves, but all 3 motors seem identical in amount of error after being tested. Faster feedrates and accelerations dont seem to change the error at all.
Generally shielding isn't needed with a stepper system. If it was some sort of "noise" causing the problem(s) it would be a 1 in 1,000,000 chance that all 3 motors would end up off the same amount after each test run.
If you mark the amount of error after test running your part. Does the machine repeat the same amount of error every time?
I assume if you do not re "0" and run the same program again you will end up apx .900 off?? Or if you run a shorter or longer program from 0.00,0.00 you end up with less or more error respectively?
If it works.....Don't fix it!
