587,220 active members*
2,566 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Problem: Shaky / stepped arcs & circles mach3 plasma
Results 1 to 11 of 11
    Sep 2015
    29
    I'm having an issue where I am trying to cutting large (15") ellipse and the arc portions are giving the machine trouble.
    The machine is jerking around the corner and it is very noticeable on the final piece.
    Is there a setting in mach3 to smooth this or do I have something set wrong in one of the configure pages?
    specs on my machine:
    4x8 plasma
    NEMA23 620oz Stepper Motors
    1000 ipm Rapid Travel
    mach3
    ESS
    sheetcam
    hypertherm 65
    Material
    14ga aluminum
    300ipm
    45 A
    136V
    THC
    The drawing was made in inkscape and the ellipse has 4 nodes
    Not sure on what I have set wrong here
    any help on certain mach3 config setting to look at would be great
    Feb 2012
    26
    Re: Problem: Shaky / stepped arcs & circles mach3 plasma
    Quote Originally Posted by snowdaze View Post
    4x8 plasma
    mach3
    ESS
    sheetcam
    hypertherm 65
    Material
    14ga aluminum
    300ipm
    45 A
    136V
    THC
    can you post your gcode?
    Aug 2006
    673
    I'm going to guess it's not mach3, but more likely a setting in sheetcam. You probably need to adjust the faceting or resolution of the arc as it converts it into line segments.
    Sep 2015
    29
    Here is are the .tap and .job files, I don't know what portion of g code you want to see, but there is 600+ lines so I didn't think I should paste it in here either.
    Attached as .zip
    Thank you
    Jun 2008
    562
    The Oval outside shape looks like a bunch of straight line segments in Sheetcam.
    Check your drawing import options in Sheetcam. Maybe increase the arc fitting tolerance.
    Mike
    Sep 2015
    29
    Thanks Mike I will take a look for that setting in sheet cam
    Sep 2015
    29
    Mike one question, how did you determine the oval looked like a bunch of small line segments?, did you zoom really closely into the part in sheetcam ? or is there another way?
    Aug 2006
    673
    you can zoom into the preview window in Mach3.
    Jun 2008
    562
    You said the ellipse only had 4 nodes, when you looked at in Sheetcam it had many more the 4. I zoomed in in Sheetcam and they looked like straight lines.
    Mike
    Jul 2005
    2415
    The segmentation happens in the DXF export. Transfer to SheetCAM directly via SVG and the arcs will be intact like in Inkscape. Also make sure CV is turned on in MACH and that CV feedrate is OFF.
    Sep 2015
    29
    Thank you for replys I will try this.
  1. Circles and arcs not smooth
    By Sheepspeed in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-24-2014, 10:23 PM
  2. Plasma cut small circles only produce short arcs
    By ronateah in forum Machines running Mach Software
    Last Post: 06-13-2011, 07:47 AM
  3. Autocad to Mach3 problem with arcs
    By LTP in forum Mach Lathe
    Last Post: 07-25-2010, 03:08 PM
  4. Cutting arcs and circles
    By inaman in forum GibbsCAM
    Last Post: 04-26-2008, 08:04 PM
  5. Cutting circles and arcs
    By Hack in forum CNC Machine Related Electronics
    Last Post: 11-08-2004, 10:12 PM
