588,191 active members*
7,976 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > totally lost and need a nudge in the right direction retrofitting an old thermwood
Results 1 to 15 of 15
    Dec 2004
    25
    ok
    so I have an old thermwood c50 (1987)that I want to retrofit with kflop/kanalog
    I just got the kflop/kanalog boards in and really don't know where to start
    I already have a license of Mach3 so will probably use it
    x axis has 2 dc servos y has one and I have 2 z's + 2 air drills
    all servos are the same baldor mte-4535-special 40 lb. in. max speed 4500 rpm max voltage 180 vdc 16.4 amps constant 70.2 amps peak
    tach 7.0 encoder 625 L
    I will be using my existing amps and power supply
    encoders have +5v, common, shield, phase-A, and phase-B
    tach has red and black wire
    arm. has red and black wire
    not sure where to start and don't want to burn anything up
    anyone have an example of what connects to where? thanks
    May 2006
    4055
    Hi Kra,
    Do you have any motor amplifiers?
    Regards
    TK
    http://dynomotion.com
    Dec 2004
    25
    yes
    using existing motor amplifiers if I can (west amp setup with 5 Baldor amps) I have 2 motors/amps for x axis and 1 for y axis and 2 separate z spindle axis plus 2 air drills
    they work and already connected to motors and wiring harness comes from these to old control with db9 connectors that plug into old control board
    I have a wiring schematic for existing setup just not sure where to hook what on new kanalog board
    thanks for any help.
    Dec 2004
    25
    db9 has the following wires
    red/white=+5v
    black/white=comm.
    white=g
    green/white=g
    yel/white=phase b
    green=phase a
    black goes to amp
    white goes to amp
    red goes from tach to amp
    black goes from tach to amp
    then another red and black from servo arm to west amp dc power supply
    May 2006
    4055
    Hi Kra,
    You will need a clearer description of what the signals are and where they go. Basically you are looking for the +/-10V analog input to the Amplifier. If you apply a small voltage (ie 1.5V battery throught a 1K ohms resistor) it should drive the motor 15%. And reversing the battery should drive the opposite direction.
    HTH
    Regards
    TK
    24220
    Quote Originally Posted by kra View Post
    Why not post the schematic, are they Westamp or Baldor drives?
    Al.
    Albert E.
    Dec 2004
    25
    the individual drives are baldor
    the schematics are on several 24x36 sheets or blueprints
    I will see if I can scan part of a sheet to show motor to amp wiring
    Dec 2004
    25
    here is a typical schematic in pdf and jpg format
    hope it is readable
    appreciate the help
    24220
    I prefer a minimum of 1000 count encoder, the 625 will give you a resolution of 625 x4 = 2500 p/rev. also differential type is better for noise resistance.
    The dwg does not show the ±10vdc command input.
    You will need to locate this shielded pair from controller to drive.
    Or maybe that is 7 & 8 of the left hand plug?
    Al.
    Albert E.
    Dec 2004
    25
    I called Baldor and they sent me the attached pdf of a similar setup that they currently make.
    He said it should have the same wiring as my older drives so it should be a big help
    Attached Thumbnails Attached Thumbnails MN1269_1269-798.pdf
    24220
    If you notice from the description, if it has the same options as your amps, the drive can be used in the torque mode, I generally prefer this method if it is available, in this case the tach is not used.
    Al.
    Albert E.
    Dec 2004
    25
    thanks al, it appears that my drives are basically the same. they were made in 2005 so not too old
    now that I should be able to figure out what wires are doing what from my motors through drives is there any drawing available to show the best way to attach everything to kanalog
    24220
    Maybe Tom has some generic style prints for analogue control he can post or send?
    Al.
    Albert E.
    May 2006
    4055
    Hi Kra,
    The basic connects required are from the Kanalog DAC outputs to the Amplifier inputs. And from the Encoders back to the Kanalog differential inputs.
    Kanalog requires differential encoder signals (A+ A- B+ B-). You encoder signals appear to be single ended (only A and B). There are cable drivers available that can convert to differential such as:
    US Digital | Products » Interfaces » Encoder » Cable Drivers
    It looks like Figure 2-3 in the manual you uploaded shows where to connect the Kanalog DAC to your Amplifiers. Kanalog would be the "Machine Control".
    There is a file in our Yahoo Group from a customer who did a similar conversion with Kanalog. See: the file Kanalog Connections.pdf
    http://tech.groups.yahoo.com/group/DynoMotion/files/
    Regards
    TK
    Dec 2004
    25
    thanks Tom
    starting to make sense now
  1. Replies: 2
    Last Post: 11-10-2011, 11:13 PM
  2. Hi - totally lost
    By ilium007 in forum CNC Wire Foam Cutter Machines
    Last Post: 04-25-2010, 01:52 PM
  3. Total Newbie... totally lost!
    By SwarfEye in forum LinuxCNC (formerly EMC2)
    Last Post: 05-31-2009, 05:20 PM
  4. Totally Lost
    By FAMOUSX1 in forum Computers / Desktops / Networking
    Last Post: 07-12-2007, 07:36 PM
  5. Need a nudge to finish IH build
    By Shepard in forum Charter Oak Automation Support Forum
    Last Post: 03-13-2007, 02:43 PM
