I own a 1997 Torq-Cut 22 with DX32 control, everything was running perfectly fine until now. I have rush jobs to complete and the machine is now down!
The issue:
All machine function work perfectly and al control/PC related fonction work perfect also. The problem is that when the spindle is turned on(rotating) the axis wont move, this is eaither in manual or automatic mode. also the manual button to stop the spindle is not working.
I this this must be a conflict with a bad board or a bad connection. It started a couple hours ago as an intermitent problem, coming and going and now it leave the machine on complete shutdown.
What i've done so far:
- Checked all connections
Now where should I go???I need the machine back on track asap and now EMI is closed and I cannot call them until tomorrow morning.
Please let me know if you have any knowledge regarding this machine or if you have experienced this problem in the past.
Thank you!
