![Quote](images/misc/quote_icon.png)
Originally Posted by
DingoHammer
JohnJW, would the Gunk have removed the paint if it had not already been softened by the coolant? You could try it on a small painted area that has not been exposed to coolant and see.
The Hangsterfers coolant that I am using, I don't remember the number but it is the vegetable oil based coolant, softened and blistered the paint on my Haas mill. The coolant was mixed to manufacturer's recommendations. I don't see how diluting the coolant more would have prevented this, it would have only made it take longer for the blistering to occur.
The paint on the Haas appears to be powder coat. If a coolant does that to paint, I wonder what it does to skin. Coolants have analogies to the snake oils of old, who knows what they contain. It is a business that seems like it would attract unscrupulous characters.
Surely there is a way to make coolants out of common ingredients that will work acceptably well as a lubricant, not peel paint, not rust metal, and not cost so much. I tried Murphy Oil Soap as a mist coolant and it worked well on the small parts I was machining. I didn't test it for paint peeling and rust prevention. If I come up with a good coolant recipe, I will post it here.
The post is over a year old!
