587,675 active members*
3,570 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > ​Homemade Mini Press Drill for all Hand tools very cheap and easy
    May 2015
    67
    Angry ​Homemade Mini Press Drill for all Hand tools very cheap and easy
    Parts and Tools:
    2 pcs Aluminium Alloy Profile 300 mm x 80 mm x 40 mm.
    Aluminium Alloy 6061 300 mm x 80 mm x 12 mm
    2 pcs Aluminium Alloy 6061 70 mm x 70 mm x 12 mm
    Aluminium Alloy 6061 60 mm x 160 mm x 12 mm
    1 Linear shaft 15 mm x 250 mm aixs
    drill or hand tools Ozito, Dremel .....
    May 2015
    67
    Re: ​Homemade Mini Press Drill for all Hand tools very cheap and easy
    May 2015
    67
    May 2015
    67
    May 2015
    67
  1. Replies: 3
    Last Post: 05-19-2015, 11:17 AM
  2. Homemade wood mini lathe with hand Drill
    By doitbymyhand in forum Wood Lathes / Mills
    Last Post: 05-17-2015, 09:51 AM
  3. DIY Wood Mini Lathe Metal Axis Homemade Tailstock with Motor Drill
    Last Post: 05-14-2015, 04:18 PM
  4. Left hand vs right hand turning tools.
    By ChrisW in forum MetalWork Discussion
    Last Post: 08-15-2013, 09:32 PM
  5. Battery powered hand drill motor for a cheap spindle?
    By BMG in forum CNC Machine Related Electronics
    Last Post: 05-11-2009, 02:57 AM
