I'm new to running a 240MS and am not understanding how the geometry offset library works. It has a 12 station turret with an offset registry of 32. If I MDI a T0808 and use the Q setter, all the information will go into the 08 offset. If I MDI a T0816 and use the Q setter, all the information goes into the 08 offset. (I've tried MDI T1608 and get an error message!) (The old cnc lathe had a 32 tool tool library with a 12 position turret that I could use tool 24 in position 6.) Can I run the 240 like this or not? Thanks!
