587,933 active members*
3,786 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Can someone help figure this out, please?
Page 1 of 2 12
Results 1 to 20 of 21
    Jan 2006
    11
    I am just beginning to work in mastercam v9.1. I have made one simple solid (in ProDesktop) for practice but I can't figure out how to make toolpath for it. Here's a pic
    I have attached file in .IGES (3 versions) and .DES format for you who want to help me.
    Attached Files Attached Files
    Aug 2005
    149
    I only see the des version...I can't use that
    Mar 2005
    461
    Windrider,
    The best format to upload would be .mc9 or a parasolid (.xt).
    Jan 2006
    11
    Yeah, I now saw that I have uploaded log files for IGES I have uploaded it again.
    Unfortunately I can't export .mc9 file from PRO/Desktop. I can export .STEP file if that suits you guys more.
    May 2006
    132
    if i were you i would first try surface rough pocket. when you figure out a few things and make it work then try surface parallel then surface contour.
    many toolpaths will work but you need to learn which one you prefer for your own procedure. i use these toolpaths the most and they are very reliable for my application. i make many prototype and short run jobs so cycle times are not as important as programming time. also i leave the machine unattended many times on unproven programs so i have confidence that they won't crash.
    May 2006
    132
    see mc9 file
    May 2006
    132
    [email protected]
    if you send email i will reply file
    Jan 2006
    11
    Thanks for your advice. I have sent you an e-mail.
    Jan 2006
    11
    I have some problems sending you e-mail. I have yahoo account and I keep getting failure notices. Do you have any other e-mail I can send to?
    May 2006
    132
    Windrider,
    I'm with Billy on the rough pocket, surface parrallel and contour are also good usually no problem toolpaths, but finish project is a great toolpath for this part. If I get some time I will post a video on what I have. I do have a sample of blend on my site. it is not your part but you can look it over to see the finish. go to the site below look for blend.
    Steve
    www.cad2cam.blogspot.com
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Jan 2006
    11
    Thank you all for your help. Billystein thanks for e-mailing me, that really helped me. I've done somethins with Surface finish/contour and I will post it later for you guys to tell me what you think.
    Thanks, once again!
    Jan 2006
    11
    I've attached my mc9 file. Is it fine?
    Jan 2006
    4396
    Quote Originally Posted by windrider View Post
    STEP Files are better with solid models than Iges.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Apr 2003
    3578
    STEP Files are better with solid models than Iges.) With this thought Iges does not support solid data only surface and Splines and Standard wire fram. but if you know the right flavor setting in Pro-e you can get a supper clean file from it to Mastercam.
    Cadcam
    Jan 2006
    11
    Will you let us know what flavor you are talking about, please?
    Jan 2006
    4396
    I'm thinking Blueberry but this could be wrong.
    Seriously, he might be talking about exploding the Geometry or something of that nature before exporting to Mastercam.
    Toby D.
    Schwarzwald
    Apr 2003
    3578
    Pro_e has for Iges diffirent options and they are refrenced by most Pro-e user as flavors of settings to output. if they are set right you get clean surface file if not you can get surfaces missing or were there should be a trimmed surface you get the parent surface be the the untrimmed surface.
    (he might be talking about exploding the Geometry) this my friend is an autodesk term usally used in Autocad.
    PS Toby how in the hell are ya?
    Cadcam
    Jan 2006
    4396
    Quote Originally Posted by cadcam View Post
    Pretty good......How the hell are you????
    I got my friend on his way with his Mastercam and he is a Happy Camper. He calls me a few times a week to say,"Did you know Mastercam can do this???"
    The job with the Mazak Lathes didn't go far because a buddy of mine needed a job and he already knew the Machines well. Needless to say, I did what I felt was best for everyone
    The Software itself is a Marvel. I'm just glad I could be of some help
    BTW: Have you seen BCC V2007 yet? It is coming along nicely. You should take a look.
    Cheers!!!!!:cheers:
    Toby D.
    Schwarzwald
    Apr 2007
    13
    long time no email windrider,,
    if u ever need more help feel free to email me if u still have my email [email protected]
    i dont regularly check this forum but i do check my emails,,
    btw big deal if iges is a little sloppy its good for practice for those of you that are a little green in the surfacing aspect of things. but yes .x_t (parasolid) is definitly the best format to convert.
Page 1 of 2 12
  1. Anyone figure out the EMCI.INI
    By anoel in forum LinuxCNC (formerly EMC2)
    Last Post: 09-23-2006, 07:43 AM
  2. Can't figure out why...
    By asher in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2006, 04:15 AM
  3. Help Me Figure the Specs of My Motor.
    By cbcnc in forum Stepper Motors / Drives
    Last Post: 08-14-2004, 04:21 PM
  4. How to figure out what servo size you need
    By replicapro in forum Servo Motors / Drives
    Last Post: 06-24-2004, 11:45 AM
