586,103 active members*
3,776 visitors online*
Results 1 to 3 of 3
    Jan 2022
    Lines on circle
    I build a cnc wood router machine with leadshine servo motor with plenetry gear box and NK105G2 controller.
    My problem is when i cut circle there is a line which is tool entering mark but exactly oppiste the tool entering mark there is one more line, which is not smooth. Please help me to solve this problem
    Jan 2008
    241
    Re: Lines on circle
    Sounds like a backlash issue?
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    Jan 2022
    Quote Originally Posted by Mogal View Post
    Sir thanks for the reply
    When i changed servo motor with stepper circle cutting is fine but with servo motor lines comes
  1. Replies: 9
    Last Post: 08-15-2018, 01:28 AM
  2. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  3. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  4. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
