SINO foam mould engraving cutting cnc router SN1530FM
Application:
The SN1530FM is mainly used for engraving and cutting polyfoam,wood,MDF,acrylic,plastic materials.It is widely used in advertising industry.
Feature:
1,Special strong cast steel structure,worktable lower than driver orbits,it is suit for feeding thick materials,guarantee the stability and precision when working.
2,Z axis high working size up to 1000mm,it is necessary to process polyfoam.
3,High-power spindle can fix thick cutter tools max diameter 13mm and max length 25cm.
Parameters:
Model SN1530FM
X Y Z axis working size 1500*3000*600mm
Max idle speed 50m/min
Max working speed 25m/min
Reposition Accuracy <±0.05/300mm
Frame Welded steel structure
X-Y-Z Structure: X Y axis rack rail,Z axis ball screw
Control command G code, u00*, mmg*, plt
Control System Germany Simens control system
Drive orbits Taiwan Hiwin square linear guide rail
Voltage 220V/380V 50Hz
Spindle Power 5.5kw water cooling spindle
Drive motor Germany Simens servo motor
Compatible software Ucancam/Type3/ Artcam
Worktable Vacuum table with dust collector
Tool Collect 3.175mm,4mm,6mm.8mm,12mm
