588,506 active members*
4,903 visitors online*
Results 1 to 6 of 6
    Jul 2007
    887
    40 taper spindle bargain (?)
    Hi guys,
    I just bought myself most of a size 40 taper spindle with springloaded drawbar. I have no idea what I'll do with it yet but I simply couldn't help myself ;-)
    I have no background on it and I don't know what type of pullstud it's supposed to work with. I was hoping it was an OTT-drawbar (so it could work with DIN2080 holders) but unfortunately it wasn't.... It's supposed to be "OK", looking at the taper it looks like it's never even been used and the bottom bearings turns smoothly and quietly.
    I took a quick a look at it today and found that one of the bearings is a SKF 234421 BM1/UP. While looking up the data on the bearing I stumbled across Midland Bearings.com and saw the retail price - £2100 YIKES.....and that's for the Standard Precision model.....
    Sep 2006
    607
    You lucky..!!!
    In fact I might get a similar one myself along with quite a bit of tooling for my next project. What are you going to do with yours?
    May 2005
    2502
    Heh, heh.
    Very substantial piece of metal, eh?
    Bearings go up rapidly as you get to the larger diameters. The better spindles situation the lower bearings very low for best leverage relative to the workload. But, this also means very big and hence very expensive bearings. I have seen other spindles let the toolholder protrude pretty far below the lower bearings allowing them to use cheaper bearings at the cost of performance.
    Cheers,
    BW
    Jul 2007
    887
    I have no idea yet what to do with it... It'll have to sit on the shelf for some time while I finish up the knee-mill conversion and a few other things, then we'll see....
    Sometime in the future I would like to build a large(ish) VMC type machine but as it is now I don't have room for it. Besides even VMC's can be had quite cheap nowadays so I don't know.... It was just one of those deals I could let past me....
    Aug 2007
    558
    Hey, that's really nice - even if it is a while before you can use it, it's a nice piece of industrial art!
    Build a VMC... Go on, you know you want to
    Best regards,
    Jason
    Mar 2006
    2712
    H.O, I think your bearings are better than you think. I believe "/UP" in SKF's language is Ultra Precision. That's pretty much top of the line.
    Dick Z
    DZASTR
  1. Has anyone got the 30-taper spindle?
    By digits in forum Tormach Personal CNC Mill
    Last Post: 07-24-2008, 03:17 AM
  2. NST 30 spindle taper...what fits this?
    By Preston E in forum Uncategorised MetalWorking Machines
    Last Post: 01-20-2008, 08:50 PM
  3. 30 MM Spindle Taper Adapter
    By JVAvitech in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-12-2007, 11:04 PM
  4. spindle taper explanation
    By jwallace in forum Benchtop Machines
    Last Post: 08-16-2007, 12:01 PM
  5. Rebuilding a 30 taper QC spindle
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-18-2006, 06:50 PM
