588,629 active members*
5,458 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Single Axis TB6560 driver and breakout board wiring
Results 1 to 6 of 6
    Feb 2007
    10
    Question Single Axis TB6560 driver and breakout board wiring
    Hello,
    I am in the progress of building a large 3D printer/mini router. I almost finished the mechanics and ended up stuck with the electronics. I bought a 5axis breakout board and 4 TB6560 single axis chinese drivers (I've heard that combo drivers are inclined to cause problems, so I preferred individual drivers). The problem is, I got no manual with the drivers and I have no idea how to connect them to the breakout board.
    I have watched quite a lot of videos and made some serious search on CNCzone, but it seems like everyone here is dealing with digital drivers (with black boxes).
    Here is the link for the drivers I've bought :
    CNC Router Single One 1 Axis 3.5A TB6560 Stepper Stepping Motor Driver Board | eBay
    And here is the breakout board:
    CNC 5 Axis Breakout Board interface for Stepper Motor Driver Mill/Input Power:5V | eBay
    Can anyone show me the connection like in the picture I attached? I know that there are a thousand of topics asking the same, but somehow I couldn't find the right answer. Please help. Sorry for my English by the way.
    Mar 2007
    2083
    the only way I can see the boards can be connected is by
    powering the breakout board by connecting a 5v supply to the terminal block
    and not the USB socket
    John
    Feb 2007
    10
    Hi John,
    Thank you for help, the motor started to turn finally The next problem I have now is the heat. The motor gets very hot when it turns for a minute. I guess it's something with the motor tuning settings. I'll need to review Mach3 manual for that.
    Mar 2007
    2083
    Hi Badboy ,
    stepper motors do run hotter than you would first expect
    about 60 or 70 degree C ! too hot to touch for more than a few seconds
    when stepper motors are bolted to the metal body of a machine
    the metalwork will act as a heatsink helping to cool the motors
    but , double check the switch settings for the motor current
    just in case your runing the motor at too high a current
    John
    Dec 2010
    313
    Quote Originally Posted by badboy View Post
    Hi John,
    You may want to check the power supplied, if your voltage is high lots of heat will be generated.
    "Energy can not be created or distroyed only transformed" the theory of relativity.
    That noted, if you supply high voltage and the motor requires low voltage the energy needs to go some place, so it turns to heat.
    You should supply the motor the Voltage it needs and not any more, the IC (TB6560) can handle a large voltage range "12-36V" but this is to cover the use of a few different sized motors.
    Hope this helps,
    Rob
    what is a cnc
    1695
    What is the current rating of the motors? Do you have the 6560 set to supply the proper amount?
    It should not get hot after 1 minute unless it is severely over driven.
  1. Single TB6560 Drivers+Breakout board?
    By Zeppelin1007 in forum Stepper Motors / Drives
    Last Post: 04-22-2016, 07:42 AM
  2. need help with 3 AXIS (TB6560) CNC DRIVER BOARD
    By Jason Miller in forum CNC Machine Related Electronics
    Last Post: 08-11-2012, 03:34 AM
  3. 5 axis breakout, TB6560 driver, 6 wire stepper
    By may in forum Stepper Motors / Drives
    Last Post: 06-06-2012, 07:56 PM
  4. CNC Kit 4 Axis TB6560 Driver Board
    By Reshek in forum Controller Cards
    Last Post: 10-27-2011, 08:25 PM
  5. Wiring Stepper, driver and breakout board
    By bdrotaru in forum Stepper Motors / Drives
    Last Post: 02-26-2011, 06:30 PM
