hi,
where can buy tool setter for z-axis?
thanks
hi,
thanks
deskcnc has one, thats all I can think of, you could buy a light up touchprobe from msc or somewhere else and wire it to the computer instead. Or you can try to make one which I tried once, plan to again in the future.
Jon
What style are you looking for? Are you looking for just a mobile type for operators at the machine? Are you looking to install one on a machine? Are you looking for an external pre-setter? Optical, laser, touch or mechanical? For what machine (CNC mill, manual mill, lathes, ... )?
Theres a ton of them for different reasons, mounting and from several manufacturers.
It's just a part..... cutter still goes round and round....
hi,
i looking for one something like that http://www.nsknet.or.jp/nisshin/en/e-frametop.htm dont know where can buy that i-50
yes, mobile type... for my little sherline cnc mill
and looking for one safety internet shop for shopping with credit card
sorry, Jon, deskcnc one look very good but too expensive to me
thanks
MSC direct has this sort of thing.
Regards,
Mark
Nisshin has to be bought direct I believe. You can also check these from Lyndex (they have 4 different models), SPI, ( or this one ) , etc.
I've even just used something simple like a 1-2-3 block. Just as long as you standardize, it works fine.
HTH :cheers:
ACME,
Electronic unit at enco:
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=951637
Ken
There is an affordable mechanical unit also but could not find it.
Personally I like dials
Here it the mechanical,
Bulkier then the one I use and not the precision but is also $250 less money and should be fine within +/- .001 or so, which ain't shabby tolerances.
Unlike th electronic versions mechanical works on all material, not just conductive.
http://cgi.ebay.com/PRECISION-Z-AXIS...QQcmdZViewItem
thanks, i got it...
Which type did you decide on ?
