588,225 active members*
4,766 visitors online*
Results 1 to 6 of 6
    Mar 2012
    378
    Pathpilot monitor resolution
    I just installed Pathpilot on my machine. I removed the computer so I could do the install in my office instead of bending down to access the computer and I used a wide screen monitor. Now that I have moved the computer back to the machine with the older low aspect ratio monitor Pathpilot comes up with the left inch or so of the screen missing. I am assuming it detected the monitor size of the other monitor during install and now it is using the same thing.
    How do I set the screen resolution on Pathpilot now? I did search some other threads and tried powering up the monitor separately so it is on before the computer boots up, but no luck.
    Jul 2016
    140
    Re: Pathpilot monitor resolution
    What version of PP? I had the problem all the time before 1.9.12. Power off/on would fix it.Edit: You can also go into ADMIN DISPLAY and check the resolution. I think PP only has 3 settings. You just have to match it to your monitor resolution.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Mar 2012
    378
    I have version 1.9.11. Foolish me thought the CD I just got two days ago would have been the most up to date release.
    Now to go search and see where to find updates and how to install them.
    Jul 2016
    140
    Download the update to a thumbdrive. Go to the Status screen and click update. https://www.tormach.com/pathpilot-up...and-notes.html
    Mar 2012
    378
    Thanks. I found the update and installed it and same issue. I did try the ADMIN DISPLAY and went to the highest resolution and now I get the whole Pathpilot window to fit on the monitor, but it is not full screen. Is that normal?
    Jul 2016
    140
    Is your monitor set to auto size?
  1. Replace old CRT monitor to LCD monitor
    By =aike= in forum Okuma
    Last Post: 01-16-2020, 08:29 AM
  2. U10M spindle load monitor and monitor mode
    By myhäje in forum Okuma
    Last Post: 02-21-2017, 08:45 AM
  3. UK Owners - PathPilot monitor recommendations and Transformer
    By AMacGregor in forum Tormach Personal CNC Mill
    Last Post: 12-20-2016, 02:22 AM
  4. PathPilot with Acer FT200HQLBMJJ Touchscreen Monitor?
    By dkaustin in forum Tormach PathPilot™
    Last Post: 01-31-2016, 12:02 AM
  5. CNC resolution
    By sinha_nsit in forum Mechanical Calculations/Engineering Design
    Last Post: 10-22-2008, 10:11 AM
