587,936 active members*
2,963 visitors online*
    Sep 2003
    174
    BMC20-Ultimax3
    Hi Guys,
    I have an old BMC20 with an Ultimax3 control on it. When I switch the machine on it takes a long time for the screens to settle down (approx 45 mins). The machine runs perfectly ok apart from this. I don't want to leave it switched on as I don't use it that often and it's a pain when I do use it as I have to wait for it to sort itself out. Both screens are a bit like a TV that's tuned off station, then after a while the image clears but it's all over to the left and the bit that's missing is on the right. Any ideas, eventually it comes good but just takes a long time. I have some photos that I could put on here if I knew how to.
    Aug 2007
    12
    Check out the DC supply on this machine. If both CRTS are unstable your +12vdc could be the cause. You will need a digital volt meter. Measure at power on and monitor voltage (both ac & dc). check again after display is stable. if there is a lot of ac on the dc supply it needs to be replaced.
  1. Hurco BMC20 Post Prosser help
    By moorport in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2007, 05:19 PM
  2. Hurco BMC20 With Dynapath Delta Control
    By Steve A. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2006, 07:22 PM
