587,947 active members*
3,514 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Strange Circles
    Jun 2009
    Strange Circles
    I was hoping someone could tell me whats going on here. Sometimes when I have a dxf file and load it onto my cnc system I get strange circles that appear in the part file that was converted from dxf. Its strange because when I look at the dxf file there is no circles in it and I dont know where they are comming from. I appreciate any pointers that someone could give ...thanks!
    Your IJ mode may be set incorrectly .
    Jun 2009
    thanks Ger ill have to look at it ...Im not sure what ij mode means anyways so ill have to look deeper into it
    Apr 2008
    51
    I get that from time to time even in IJ mode, so I use this program to check out the g-code 1st.
    http://www.cncedit.com/
    322
    Just out of curiosity, what program made the DXF file and what CAD / CAM program is showing these circles?
    I have seen these referred to as 'crop circles' elsewhere and also here on CNCZone. They are usually an artifact of a arc segment being incorrrectly generated.
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
  1. Repeating circles?
    By bigz1 in forum G-Code Programing
    Last Post: 08-02-2009, 11:59 PM
  2. circles arent circles
    By xlr8r in forum DynaTorch
    Last Post: 01-18-2009, 06:26 PM
  3. Polyline Circles
    By ger21 in forum Autodesk
    Last Post: 09-15-2008, 04:53 PM
  4. Circles and Mach 3
    By b1driver in forum Mach Software (ArtSoft software)
    Last Post: 03-17-2008, 12:39 AM
  5. help with circles
    By phe259 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2005, 01:30 AM
