Hi I am looking for a list of G and M codes for a Mazak M32 controler on a vertical machining center. Any help will be appreciated as I am new to this controler. I have run Okuma and Haas in the past.
Thank You
Rob S![]()
Thank You
Rob S![]()
Mazak Programs G-Code a lot like Fanuc, Yasnac, and HAAS Controls. The G98/G99 Initial point and R Point Return for the Canned Cycles are the same. I believe the Sub-Programs (M98P????L????) are the same as well as the WPC G54-59.
All the Basic Miscellaneous Codes are the same too. M0,M1,M2,M3,M4,M5,M6,M8,M9, and M30.:cheers: Welcome to CNC Zone
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
G00 Positioning
G01 Linear interpolation
G02 Circular/Helical interpolation CW
G02.1 Spiral interpolation CW
G03 Circular/Helical interpolation CCW
G03.1 Spiral interpolation CCW
G04 Dwell
G07 Imaginary axis interpolation
G09 Exact stop
G10 Data setting
G17 XpYp plane
G18 ZpXp plane
G19 YpZp plane
G20 Inch input
G21 Metric input
G22 Pre-Move check function on
G23 Pre-Move stroke check function off
G27 Reference point return check
G28 Reference point return
G29 Starting Point Return
G30 Return to 2nd - 3rd - 4th reference point
G31 Skip function
G31.1 Multi-step skip function 1
G31.2 Multi-step skip function 2
G31.3 Multi-step skip function 3
G38 Cutter Diameter Offset Vector Selection
G39 Cutter Diameter Offset Corner Arc
G40 Cutter compensation cancel
G41 Cutter compensation left
G42 Cutter compensation right
G43 Tool length compensation +
G44 Tool length compensation -
G45 Tool offset increase
G46 Tool offset decrease
G47 Tool offset double increase
G48 Tool offset double decrease
G49 Tool length compensation cancel
G50 Scaling cancel
G51 Scaling
G50.1 Programmable mirror image cancel
G51.1 Programmable mirror image
G52 Local coordinate system setting
G53 Machine coordinate system selection
G54 Work coordinate system 1 selection
G55 Work coordinate system 2 selection
G56 Work coordinate system 3 selection
G57 work coordinate system 4 selection
G58 Work coordinate system 5 selection
G59 Work coordinate system 6 selection
G60 Single direction positioning
G61 Exact stop mode
G62 Automatic corner override mode
G63 Tapping mode
G64 Cutting mode
G65 Macro call
G66 Macro modal call A
G66.1 Marco modal call B
G67 Macro modal call A/B cancel
G68 Coordinate system rotation
G69 Coordinate system rotation cancel
G71.1 Chamfering Cycle 1
G72.1 Chamfering Cycle 2
G73 Peck drilling cycle
G74 Counter tapping cycle
G75 Canned boring Cycle
G76 Fine boring cycle
G77 Canned back facing Cycle
G78 Canned boring Cycle
G79 Canned boring Cycle
G80 Canned cycle cancel/external operation function cancel
G81 Drilling cycle - spot boring/external operation
G82 Drilling cycle - counter boring
G83 Peck drilling cycle
G84 Tapping cycle
G85 Reaming cycle
G86 Boring cycle
G87 Back boring cycle
G88 Boring cycle
G89 Boring cycle
G90 Absolute command
G91 Increment command
G92 Machine coordinate system setting
G94 Feed per minute
G95 Feed per revolution
G98 Canned cycle initial level return
G99 Canned cycle R point level return
G1-G255 User Macro G code call 10 maximum
JR Walcott
Georgia Machine Tool Resources, LLC
im very very new to cnc and have been running basic programs on a mazak. i would like to learn how to start writing programs to better myself at my job. how would i go about getting the m-codes for the mazak machine?
yes, thats what i use now for programming. i was looking for something to do on my pc and then take it to the mazak for use.![]()
im not sure, i guess i will ask my supervisor tonight.
If you want to get real fancy, you can program Mazatrol using the 3-digit G-code method and take it into the control...yes, thats what i use now for programming. i was looking for something to do on my pc and then take it to the mazak for use.
It's just a part..... cutter still goes round and round....
