588,009 active members*
3,073 visitors online*
    Mar 2013
    5
    Question Lifting an 86 QT10N
    hi guys,
    Is it acceptable practice (not going to stuff the machine) if I have it lifted from underneath with a fork lift?
    This is the recommended lifting method (from the manual)
    but the problem is that anything that i get to lift it in that configuration is going to make it way too tall to get into my shed.
    I've seen a lot of photo's of people lifting CNC machines from the bottom with a fork and it sits on it's base on the ground, so i assume it is alright?
    Cheers,
    Trav
    Jul 2010
    62
    Re: Lifting an 86 QT10N
    No problem lifting with forklift close to floor but much safer to lift with slings off truck.
  1. QT10n with t2
    By xa-mont in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-20-2018, 01:10 PM
  2. Mazak QT10N T2 - Basics
    By ic-cnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-03-2015, 12:06 PM
  3. Need help with Mazak QT10N ATC T3 manuals and parameters
    By Donatello Tam in forum Chinese Machines
    Last Post: 12-04-2013, 05:52 AM
  4. Need help with QT10N ATC T3 manuals and parameters
    By Donatello Tam in forum Machinery Manuals / Brochures
    Last Post: 03-18-2013, 07:07 AM
  5. mazatrol cam t2 qt10n
    By saul in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2009, 06:23 PM
