588,357 active members*
7,734 visitors online*
Results 1 to 6 of 6
    Apr 2011
    720
    Scary False Alarm
    All,
    I had a scare this morning, I was sure my spindle bearings were going bad!
    In the middle of a job, the maching started making a loud rumbling sound, and I thought for sure the spindle was bad, because it made the noise even while the table wasn't moving.
    Turned out to be a lot simpler, I use a Tormach PDB and the small "leg" that holds the actuator up level, had somehow jumped out of the slot and was allowing the ram to touch the top of the drawbar.
    So if you hear weird noises, it just might be something simple.
    Terry
    Jan 2012
    789
    Heh. That's awful nice in comparison, eh?
    Apr 2011
    720
    Yep, I was one happy camper when I saw what was really going on!
    Jun 2012
    111
    That has happened to me a couple of times. It usually occurs when making heavy cuts.
    Jun 2012
    Wohoo! That’s scary! Haha..Been there, man!
    May 2011
    180
    Quote Originally Posted by MFchief View Post
    Mine did exactly the same thing. I seem to recall bending the little bracket to make it more secure. Number of times I have needed to change belt speeds equals exactly zero at this point, so I basically made the leg fixed.
  1. Scary Stuff
    By ToyMaker in forum Safety Zone
    Last Post: 03-30-2015, 03:10 AM
  2. z-axis scary plunge...
    By Wooden Payload in forum Tormach Personal CNC Mill
    Last Post: 12-06-2011, 09:44 PM
  3. Need help on a scary problem....
    By kentsui in forum Fadal
    Last Post: 04-20-2010, 06:24 PM
  4. MACH3 is starting the router on its own... Scary!!!!
    By bjacquet@centur in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2008, 06:12 AM
  5. E-stop false triggers
    By Mooser in forum Xylotex
    Last Post: 12-16-2007, 04:52 PM
