587,702 active members*
3,481 visitors online*
    Dec 2004
    411
    1/2"-8 ACME 2 Start (4 turns per inch)
    Has anyone in oz found a local supplier for twin start?
    I rang up the manufacturers of acme in Sydney and they thought I had two heads.
    Still not sure whether to go threaded rod or timing belt pulley.
    Cheers
    Andy
    Mar 2005
    8
    Re: Acme thread
    Hi Andy,
    You could try these guys.
    www.tea.net.au
    They are about 17 Km from me & yhey have all sorts of usefull gear.
    Steve
    Aug 2003
    327
    Hey Andy,
    I've decided to use timing belts for the X-Axis on mine.
    The length of rod required, plus the nut will cost heaps, comapared togoing toa wrecker and pulling the timing chain off a twin-cam unit.
    Hows the project progressing?
    /Michael
    Dec 2004
    411
    Michael
    Good thought and would like to explore it further.
    Do you fancy chatting over lunch? I can come into the city any day really.
    Projects coming along well. gantry now rough assembled and operating. Just starting on getting the bearings assembled on the y axis. Still have some significant on-going design issues to overcome. Was reading a thread this morning about yaw and pitch. Fantastic article but it highlights that my design is prone to problems in that regard. I can overcome it but it will all take time to work through. I find the design aspect absolutely fascinating.
    Would love to hear about the problems you've been having to solve.
    My mobile number is 0418 105 568.
    Cheers
    Andy
  1. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
  2. Turns per inch to metric conversion
    By sixpence in forum DIY CNC Router Table Machines
    Last Post: 08-28-2004, 08:19 AM
  3. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
  4. what acme tap do I need for the Enco ACME rod?
    By AJ_Mac2001 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2004, 02:24 PM
