587,442 active members*
3,275 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC15XT oil pump not cycling
    Apr 2014
    345
    So the oil pump is not cycling on the machine the gauge won’t build pressure. I took it a little apart and the seal for the piston looked good but it still won’t cycle.
    I’m pressing on the solenoid to cycle it but getting nothing. Can anybody help me with what I need to do to diagnose the issue. It almost seems like the air is not ever getting to the piston to pump it.
    Pictures, instructions, or anything will be greatly appreciated.
    Jan 2015
    417
    Re: Fadal VMC15XT oil pump not cycling
    On the first CS after power on the machine my 15xt will pressurize the waylube
    Jan 2015
    417
    Or while the machine is on Pull relay K19 in the back cabinet 1100-2 board plug back in and you should hear the valve activate
    Apr 2014
    345
    Well after messing with it a whole lot and disassembling it it started working. The solenoid was acting weird but after some cleaning it has started to work.
    I also found out that leaving the machine at the y axis limit will overheat the motor.
  1. Replies: 2
    Last Post: 02-17-2018, 02:16 PM
  2. So how much is a Fadal VMC15XT worth these days?
    By Houndogforever in forum Fadal
    Last Post: 09-21-2016, 06:53 AM
  3. Need Help getting my Fadal VMC15XT (1998) to 'boot up'
    By segvargas in forum Community Club House
    Last Post: 10-05-2013, 06:33 PM
  4. Replies: 1
    Last Post: 04-01-2013, 07:12 PM
