588,616 active members*
5,555 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > here is a "rebuild" of my lathe with an improved turret design
    Jul 2008
    199
    friends,
    i have rebuild my lathe. The lm guides, balscrews, motors and vfd is the same. All is mounted on a newly casted iron bed , a new headstock and new bearings and a new enclosure with external controls for feed hold, spindle, cyclestart, coolant and estop. There are two mpg one each for x and z of my lathe. One switch for jog toggle and a homemade joystick for fast jogging.
    The new thing in this lathe is its toolchanger. completely electric deisgn. a 200watt reversible motor, a worm gear, 8 photodiodes an atmega16 is used to drive it. The best thing about the toolchanger is that it locks the toolplate with the turret base using a screw and nut so there is absolutely no deflection on the tool what so ever load is due to heavy cuts. Watch the video and pics and you will get it.
    [ame=http://www.youtube.com/watch?v=0b3ImCmnPPQ]100_6802.flv - YouTube[/ame]
    jasminder singh
    Attached Thumbnails Attached Thumbnails 100_6801.jpg   100_6804.jpg   100_6807.JPG
    It is better to die for something than to live for nothing.
    Mar 2007
    304
    Jasminder,
    - Can you post more detailed pictures of your lathe tool changer?
    - I'd like to understand how you are using the worm-gear drive.
    - It sounds like a marvelous idea to increase your ability to resist cutting forces
    Thanks!
    Joe
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Jul 2008
    199
    Dear Joe,
    Unfortunately, i have no pics or cad design for you. The turret was good in operation but tricky. It was slow in indexing but clamping, rigidity and repeatability was very good. I hope you would have seen tool post type four station turrets. if not then just google for them. They have a small motor and a worm gear in them. I took the idea from them and made a vertical turret that's it. But if someone wants me to build something better i will go for the "German revolver" plan as made by dumpster. (He is popular here and on youtube). You know, pneumatic clamping, a stepper for indexing that is quite easy to make and operate. I have made that one too in the past. Very easy and rigid and no wear at all.
    regards,
    Jasminder Singh
    Jun 2006
    Re: here is a "rebuild" of my lathe with an improved turret design
    I'd love to know more about your new cast iron bed as well.
    Thanks!
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Brilliant Design 72"x36"x9" CNC Router (HobbyCNC based)
    By vondeliusc in forum DIY CNC Router Table Machines
    Last Post: 06-01-2011, 05:14 AM
  4. Hitachi HT 20 CNC Lathe "turret index time over alarm" after battery change
    By surfit in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 04:35 PM
