588,492 active members*
4,558 visitors online*
    Jun 2006
    Macro DPRNT please help
    I am trying to use macros to monitor Haas VF-3 8/97 machine thru RS-232 output
    I used informations from topic on this forum: topic Programmed RS-232 output, but i cannot make it running
    In my program I added G65 code like this
    001 %
    002 O2893
    003 N1 G20 G65 P1111
    165 N155 M30 G65 P2222
    And I made macro like this:
    001 %
    002 O1111
    003 POPEN
    004 DPRNT[START]
    005 PCLOS
    006 M99
    When I start program, I get alarm 535-Illegal DPRNT statement
    What is wrong, please help
    Thnx
    Jan 2006
    4396
    Unhappy Macro Trouble
    Did you refer to the Tech Manuals or HAAS Tech Support. That alarm doesn't seem to be listed in the standard operators manual I used.
    tobyaxis
    304
    Try this link for your alarm.
    Nov 2003
    236
    Dprnt
    Try something easy first. Maybe the following:
    N1 G103 P1 (LIMIT BLOCK LOOK AHEAD);
    N2 DPRNT[***MEASURED*INSIDE*DIAMETER***];
    N3 DPRNT[];
    N4 G103; (RESTORE BLOCK LOOK AHEAD)
    If you are still having trouble you can always call your dealer or the Haas Automation Applications department for help.
