I dont think I have ever seen this idea for a support table before so I though I would throw it out there...
I never really understood the idea of using flat ribs of steel to support the material. They warp, and get cut or welded to and have to be replaced often. So I decided instead to support the material on a grid of 10-32 screws.
I used a 1/2 in sq tube frame and drilled holes in a 4" square pattern. From the bottom of the frame I screwed into coupling nuts resting on the top (these screws are just long enough to go into the coupling nut 1/2 depth). This provides a good stiff base to screw in a shorter screw from the top wihich actually provides the material support. This is actually an inexpesive, but very sturdy and easy to maintain setup since I only have to replace a few damaged screws on the occasion I actually cut into the support screws....and to this day I have not yet had to replace a coupling nut but that will be very easy do if needed.
