588,212 active members*
4,406 visitors online*
Results 1 to 7 of 7
    Feb 2005
    7
    Scaling Units/Inches for Mach2 and MaxNC setup
    Hello,
    I am running Mach2 on my MaxNC with a Xylotex board.
    If I want to travel 1 inch, the screen reads 10 units. This also seems to be making my CNC programs 1/10 of their actual size.
    Can anyone help?
    Thank you.
    Nov 2004
    118
    Quote Originally Posted by EPM
    It sounds to me like you need to set your Pulses Per Unit. This is under the motor settings and change it to 10 more. Example 2000 to 20000 That should fix it (Only if it is 1/10th)
    Hope that helps
    Brian
    Feb 2005
    7
    Will that have any affect on my motors?...or is there a limit to how many pulses per unit they can run?
    Thank you for the input.
    Feb 2005
    7
    So what does the scaling button next to the readout units do?
    Any help would be great...I really need this problem solved because it is holding my work up.
    The motors don't know (or care) how many units they're moving. You send the motor a step - it moves one step. You're problem is you don't have the correct number of steps/unit set correctly.
    Nov 2004
    118
    The Scale button is for making a part bigger or smaller... You NEED to have you steps per inch right first try to get the move to match the computer readout and you will be good to go
    Good luck
    Brian
    Jul 2006
    887
    dont know if you have this figured out yet.
    But you need to have 32000 steps per inch on the Maxnc 15 machine
    This is determined by the lead screw pitch.
    Robert
