588,225 active members*
4,648 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Dec 2004
    18
    tri-power overhaul
    Hi Folks,
    Here goes my real first post. Been here a long time lurking and learning, now time to share and give back
    Traded my old shoptask machine and got a tri-power with my cnc stuff refitted, ball screws and dro. I ended going that route since there was a couple feature I wanted that was on the new machine and the price was right. Yes I know there are some issues but nothing I can fix. Now I am going to set off on a project similar to what Bloy2004 did. Started stripping the machine so that every part can be cleaned (biggest problem I think with the machine is the mating surfaces are full of junk causing possible alignment issues), repaint correctly and re-assemble correctly. Change out the Nook 0.004 ball screws for the Nook 0.00015 version. And so on ...
    I will try to keep a photo history like Bloy2004 and share my experience with the Tri-power. I like the machine, just need to get the accuratacy up. Like to chat with other tri-power users on tips, tricks, and ideas on what they did to their machines.
    Cheers,
    Roberto
    May 2006
    16
    Re:Tri-Power overhaul
    Roberto,
    Hi, sounds like a big project. There are many things that need to be fixed. I have a late 2006 manual Tri-Power that I am in the early planning and procurement process of CNCing.
    I plan on eliminating the y power feed during the conversion. The compromises made in order to make the y work are to limiting. Wonder what you think about this since you formerly had no power y. Actually, do you use the manual modes since you have CNC?
    I made a DRO for the x axis that seems to work pretty good. Haven't done the others. Figured out the table rotates to much when changing x direction. Planning on making a removable plate that will be made to attach between the saddle and the tail stock base to extend the width to eliminate rotation. I will also be stiffening the fifth column and the horizontal plate to it and making a counter weight for the mill head.
    I have some other silly ideas if anyone wants to hear them.
    Mike
    Dec 2004
    18
    Hi Mike,
    Yes, big project, but looks like a ton of fun ! Took a while to dismantle everything and notice a problem with the table. So I removed everything and noticed the table has a 1/2 inch bow. So in the process of fixing that and when I re-install the machine base, shims are going to be need to make sure the machine stays aligned. I will start posting pics at that point.
    The thing I hated with my old machine was every time I wanted manual mode, I had to pull a bolt then put the bolt back and recheck everything. Drove me nuts ! I have not played much with this new setup, honestly it was something I wanted so only time will tell. I used my machine more in manual mode in the past to do little things here and there. Now I want to do more cnc and need precision hence the full tear down and rebuild.
    No ideas are silly ! Lets hear them, the more we share and exchange ideas the better the machine will be and the more fun we can have
    Cheers,
    Roberto
    Dec 2006
    90
    1/2 Inch Bow!
    Wow are you serious, a 1/2" bow?
    I just joined today, thinking of buying a manual/DRO system to start so this is kind of scarey. Is that pretty unusual, hopefully? Would it not be considered a manufacturers defect?
    Thanks much,
    Dec 2004
    18
    Hi Gerry,
    Welcome aboard ! I should note if I did not already mention it, my system was damaged in transist. Fedex frieght (they are great but ...) destroyed the shipping crate, broke a couple a minor parts on the machine and bent up the table with the forklift. It almost looks like they dropped the skid at some point. There should be some upward crowning since the weight the machine will then flatten it out vs bowing the opposite direction, but was alot above that !
    Nothing a little repair work can not fix real easy. Since I am tried of the yellow color and was planning changing it from the start, I noted the damages on the tag and John at Shoptask has been standing by with replacement parts if needed.
    Cheers,
    Roberto
    Quote Originally Posted by gerryv View Post
    Thanks much,
    Dec 2004
    18
    Assembly process ...
    Here is the start of the pics, please excuse the junk in the background. Limited on space and in the process of rebuilding my shop also ....
    Here is the table, all cleaned, fixed and repainted:
    Here is the bed installed. The support bars where put down with sealer behind them to seal the holes. All squared and level
    Still some yellow to clean off ....
    Lathe head installed. Required work on repairing the bushing that guides the gear for the tri-power x/y screws .... When I started, the gear could only be turned with a wrench and some serious force. Now it turns by hand, required shimming the back of the bush until square with the shaft.
    The bed is fully level and square. The lathe top is squared, the lathe bottom is not and needed adjusting. Shimming the back corrected the problem .... 0.040 on the left and 0.044 on the right
    More to come once new supply of shim stock arrives ...
    Cheers,
    Roberto
    Dec 2004
    18
    Hi Everyone,
    More updates and work ....
    The lathe head unit was so out of wack that it was easier to re-surface the base and make it square. Turned out we had to take 0.05 from side to 0.08 to the other side. Now the lathe head sits correctly on the bed and without shims is perfectly level (to 0.0005, the best my machinist level goes to or 0.00005 with my best dial !!) on the X and Y axis. Pinned it and torqued the bolts, waited 24 hours, re-torqued, waited 24 hours and re-checked, everything still in spec. The tail stock will have to be milled so that it sits correctly, now its too high.
    BTW, if you removed bolts, REPLACE them. Here is what happened to me after torquing this one to 65 ft lbs. Others snapped ! Got replacements on everything from McMaster & Carr.
    Once the correct bolts where used, the mill tower and swing arm where installed and torgue to make sure everything stayed level. It did
    The swing arm is level along the X axis, off around 0.008 on the Y axis. With everything torque down and no bracing, the deflection max X, Y and Z axis is +/- 0.005, not bad, was counting on more.
    Here are some pics of the lathe, motor box, and table drive in place.
    The lathe gearbox was fully rebuilt and running very smoothly now. The bushings needed shimming and cleaning. The same applied to the table gearbox for the exception of de-burring the gears and shafts.
    Now working on the bearings in the drive box. The belts and bearing are way too noisy and rough. They make the whole machine vibrate. New precision replacement bearing have been ordered and should be here in two weeks.
    Once the motor drive box works smoothly and quietly without converting to VFD, I will tackle the tail stock and table. Will convert the table X and Y axis gibbs to a full floating version so no binding from the adjustment screws.
    Cheers,
    Roberto
    May 2006
    16
    Hi Roberto,
    Looks like your having fun! Great work and great pictures. I noticed the same issue with the bolts, see: http://www.cnczone.com/forums/showth...324#post271324
    Did you re-tap the holes deeper? Some of mine are only about 3/8 in deep. Is it possible to drill them deeper and then re-tap without messing them up worse?
    You mentioned that the deflection was +/-.005 in x,y and z. What load did you use for that deflection. Also what directions are x,y and z so we are talking about the same thing. I use x for right to left, Y for front to back and z for down to up. Don't know if this is correct for mach3 since I haven't finished adding CNC yet. I think I recall posts about changing the coordinate system between milling and lathe work.
    Pushing the mill head for and aft is by far the least stiff direction. I plan on stiffening up the fifth column by bracing it for and aft and attaching it directly to the lathe bed in some fashion. By the way the quadralift locking lever that pinches one of the rods seems to have no effect on my machine.
    I'd like to see any pictures you can take of the lathe bearing replacement as I'm sure mine will need that.
    regards
    Mike
    Dec 2004
    18
    Quote Originally Posted by bicycleboy View Post
    Hi Roberto,
    regards
    Mike
    Hi Mike,
    Thanks and yes I am, great stress reliever
    The direction I talking about is the same as the machine movement axis. The loads I was using was a static 200lbs. My main goal was to make sure that with additional loads on the swing arm and quill, the larthe head stayed put and no changes happened. So with a changing load on the quill, my test shaft in the lathe head stayed at 0.0000 .
    The fifth column brace is still removed and will not be reinstalled until a couple strong backs are installed to make it even stiffer. I going to modify the fifth column big time. Working on a design that gives me the strength, stiffness, and no flexing so the it can move up and down via cnc automatically. More to come on that later ....
    Yes, all the bolt hole where retapped and cleaned. I found a couple shallow ones and when investigating, found them packed with stuff and cleaned out really well.
    My lathe bearing was in great shape and reused so I have no pics on that. Taking that gearbox apart is rather easy but the very large snap ring that holds the lathe gear in place is only removable when the the top plate is removed exposing a large hole at the top of the lathe head.
    I will take more pics of the inside of the lathe unit when I take the swing arm off again for machining. Applied is a great source for the bearings, they have stock on a ever single bearing used on the tri-power ( http://www.applied.com ).
    Cheers,
    Roberto
    Dec 2004
    18
    Hi Everyone,
    After a wait, finally got all the quality replacement bearing for the motor box. Spent some time installing the them and what a heck of difference !! Very very smooth and quiet. Still using the original belts, however replacement belts from Dayton have been ordered and waiting.
    Once I have the new belts and the last of the lathe vibration removed, I can concentrate on finishing the tail stock, table, and saddle. Then all new wiring, the stock stuff is too light in size .....
    Cheers,
    Roberto
    Roberto,
    Any chance of you posting the Applied #'s on the bearing and their cost?
    Alex
    Dec 2004
    18
    Quote Originally Posted by asallwey View Post
    Roberto,
    Alex
    Alex,
    More than happy to do so, have those handy at home, give me a couple days. One of the bearing I wanted Applied was out of stock and required a minimum order of 10 to get a back in stock and good deal. If several people combine their efforts, bearing costs can be reduced by $120.00.
    For the group,
    I installed new dayton belts from Graingers and what a hell of difference !! The machine had a nasty vibration when I started that would shake stuff off the table and now very smooth, almost like a heavy quality lathe. I did discover a slight vibration in the lathe motor that can dealt with in a couple ways. 1. Isolation pads so the motor is not directly bolted to the lathe unit (best way to do it) .... 2. replace the bearings in the motor (something that should be done no matter what .... 3. Do item 1 and 2 and do it right up front.
    Side note, the dayton belt size for the 2 belts on the lathe motor are wrong and will have to get with John at Shoptask to correct that. If you use those sizes, you then have to run both belts under the idler pulley to get enough tension to work right. Otherwise you end up adjusting the motor so much that it hits the table and the belts still slip ....
    Cheers,
    Roberto
    Dec 2004
    18
    Quote Originally Posted by morbius View Post
    So today had a little time to spare and removed the original lathe motor and installed the mill motor in its place (they are the same). Wham, the slight vibration gone and the lathe setup runs very smooth !!
    Ran it for about 30 minutes at the max speed, smooth and steady !! The noise that I can not fix is the gearbox inside the lathe head .... Should have been shimmed but was not. But then not like you are going to hear it when cutting metal.
    Now will have to take the lathe motor apart and replace its bearing ....
    Well getting there little by little.
    Cheers,
    Roberto
    Dec 2004
    18
    Hi Everyone,
    Here is the requested bearing numbers, prices, and qty from Applied.com.
    These are not the cheapest nor the most expensive, they are the one that suits the function and speed.
    Fixed idler - 4021618 - $23.82 - qty 2
    Tension pulley - 2519460 - $11.65 ea - qty 2
    Roller shaft on clutch arm - 4513412 - $13.41 ea - qty 2
    All other inside belt box - 4021677 - $21.12 - qty 8
    Note: I did not change the bearings on the lathe itself since there where in excellent shape and just needed a little cleaning. The bushings where also good and a little steel wool worked a miracle.
    Here is the information on Dayton belts from Graingers
    Dayton 3L240G - qty 2 (I think these are slightly too big, but fully useable, will update when I find the exact size)
    Dayton 3L250G - qty 1
    Dayton 3L300G - qty 1
    I hope that helps. Those changes took a machine with heavy noise and vibration down to a good old fashion heavy iron lathe and smooth !
    Cheers,
    Roberto
    Thanks Roberto!
    Dec 2004
    18
    Most welcome, glad I could help !
    Side note, some of the bearing will be hard to remove even though they feel loose. Once you get the old bearings off the shafts, take a file and re-round/clean the edges of those shafts. When the bearing where installed, they must have fit fine but then some heavy handed person mashed the hell of the shafts when tightening down. The ends on flared out a little.
    Never could understand why people of have to tighten things down to the point something breaks of deforms. The it the problem with this machine, its either very loose, or so tight that things are bent ..... Once I removed all the bolts, all holes where cleaned and chased/re-tapped, cleaned again, new bolts used and correct locktight for the usage. The bolts came out with large wrenches and new ones went back in with fingers till finger tight and then torqued
    More to come later.
    Cheers,
    Roberto
    Dec 2006
    90
    Hi Roberto,
    Did you ever get a chance to finish blueprinting your tri-power. The pic's were great so it would be nice to see the finished product and any thoughts on if you're happy with the machine functionally.
    Thanks much,
    Dec 2004
    18
    Hi Gerry. At the moment, the tri-power is on hold while shop construction work is in progress. As soon as that is done, I can get back to the tri-power and get it all finished. Cheers, Roberto
    Nov 2007
    55
    It's interesting to see that changing the bearings made such a difference since the bearings in my Eldorado don't seem bad just with a 'hand-test'. I replaced all the lathe drive belts with the cogged style and it did make it a bit quieter.
    But I found out that you can't use cogged belts for the two matched belts that are on the motor, as the inside of the nearest belt has to ride on the small idler pully while under load, and the cogged belt will slip off the idler after it wears a bit. I was using metric 560 lengths for those two belts. They also were a bit longer than the factory belts but could be adjusted to work.
    Denny
    Jul 2003
    586
    what size are the spindle bearings and are they worth replacing, if so any idea how wuch they would cost?
Page 1 of 2 12
  1. Ball screw overhaul
    By N4NV in forum Linear and Rotary Motion
    Last Post: 10-02-2008, 03:47 PM
  2. VFD Conversion/Overhaul ?
    By Verboten in forum Phase Converters
    Last Post: 04-21-2007, 04:05 AM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Do's and Don'ts of CNC lathe overhaul?
    By zoeper in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2006, 05:26 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
