588,342 active members*
5,114 visitors online*
    Sep 2007
    4
    The A word in G76
    Hello... I am a retired teacher. Spent some time teaching "early" CNC Gcodes.
    I have a question about modern machines: Since the new machines are so tight with ball screws do you still program the threading angle at 29 degrees? It seems to me that the machines I have watched threading are cutting both sides of the thread equally (read chips curling from both sides) and both the leading and back sides finish rather nicely and at high speed. I looked it up and found the G76 cycle which uses the A word for tool angle. That is not the same as setting an old compound lathe to 29 degrees is it?
    Thanks for reading
    Ron
    May 2004
    4519
    Yes, you can. 29 degrees. 30 degrees. 0 degrees. Several lead in options. Modern machines also have different cutting patterns available. Yes, it is basically the same as setting a compound angle on a manual lathe.
    Sep 2007
    4
    Quote Originally Posted by txcncman View Post
    Thanks! things have come a long way. I wonder still how many people programing turning centers use the old way because like I said I go to shows and they are cutting threads on both sides of the tool and getting really nicely finished parts. Do you do that? We had a Haas and just threaded straight on. The machine was pretty new but that was 15 years ago.
  1. Word!
    By Fabio1 in forum Canadian Club House
    Last Post: 09-07-2010, 08:30 PM
  2. g and f word on every line?
    By july_favre in forum Post Processors for MC
    Last Post: 01-22-2007, 11:16 PM
  3. A word of thanks to the moderators!
    By widgitmaster in forum Community Club House
    Last Post: 11-25-2006, 01:04 AM
  4. How do we get the word out??
    By AMCjeepCJ in forum Milltronics
    Last Post: 12-29-2005, 03:04 PM
  5. A word about CNC Pro
    By boxwood in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-23-2005, 04:02 AM
