587,745 active members*
2,717 visitors online*
Thread: Part counter
Results 1 to 6 of 6
    Mar 2009
    291
    Part counter
    What do i need to add to my program to get the parts counter running.I have a Fanuc21i-mb control.
    Sep 2007
    133
    i know nothing about these machines sry, but if i want to guess i would try adding M25 just before the M30 (end of program)
    May 2009
    393
    Part counter is automatically configured to increase by 1 after M30.
    Ash
    Jun 2007
    119
    What values has parameters 6700 and 6710 ?
    if param. 6700 #0 =0 then M02 or M30 should go
    if param. 6710 has a value other than 0 then put a M whit this value at the end of program
    Feb 2006
    1792
    M02 and M30 would always increment the part count, unless 6700#0 is set to 1.
    In such a case, the count would be incremented by the M-code, stored in parameter 6710. This number can be same as or different from 02 or 30, but not 0, 98 or 99.
    Do not miss EOB symbol after M02/M30/..., otherwise count would not be incremented, possibly without any error message.
    #3901 contains part count, as read/write variable.
    Mar 2009
    291
    parts count
    ok got it m54 before m30 .thanks everybody
  1. Need help on Part Counter
    By fahed in forum Uncategorised MetalWorking Machines
    Last Post: 03-27-2010, 08:57 PM
  2. Part Counter Reset
    By Outlaw6700 in forum Milltronics
    Last Post: 02-27-2010, 12:00 AM
  3. turn on part counter in eia on MAZAK nexus vertical mill
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-31-2008, 03:49 AM
  4. Changing Fanuc part counter increment?
    By gearsoup in forum Fanuc
    Last Post: 06-23-2007, 01:50 PM
  5. Part Counter
    By ParadiseIsle in forum FlashCut CNC
    Last Post: 06-14-2007, 02:04 AM
