Originally Posted by
slcoleman
I have a MicroMark benchtop milling machine which came with a tapered shaft/chuck assembly for holding the endmill, and it seems as soon as the bit touches the workpeice the chuck falls of and damages the project. It doesn't matter how hard I try to seat the chuck on the taper.
I could be wrong here ( it has happened to me once or twice before ) but it sounds like you are missing a drawbar to tighten and hold the chuck or collet in the spindle.
You can make your own drawbar with a short length of threaded bar that matches the thread on the thin end of you chuck, you just need enough to stick up a little above the top of the spindle ( remove any removable cap on the top of the spindle ), then cap it with a good sized washer and then finally a nut to tighten the whole arrangement. ( you dont have to tighten it by much, otherwise you will be hammering on it to release when you want to change chucks/collets )
Tim
Current glazing motto:- Cut to size, Beat to fit
