Do you have the schematics? If the breaker feeds several sources then it will be a process of elimination, hopefully using the schematic.
Disconnect a breaker load one at a time until the breaker stays in, once the circuit is identified then further diagnosis can go from there, this procedure and a good multi-meter should do the trick. Most likely L5 & L7 are single phase 120v or 220vac.
Al.
Albert E.
