588,533 active members*
9,337 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Machine stop / Spindle Stop with a Dwell
    May 2008
    157
    Smile Machine stop / Spindle Stop with a Dwell
    I have a right angle head which is not supposed to run continuously beyond 45 mins. I have an operation with this head which runs for more than 90 mins. Is there a possibility of giving a stop after 45 mins (which i can control within the program), Stop for 10 mins and then start from the point where the program had stopped ?
    I cant use a M00 as there is no time control as such (I assume M00 cant be combined with dwell). I may be able to use M05 and then dwell in the next line and then M3 again and start the program but is there a simple single line approach for this issue ?
    Thanks a lot for all the help
    Sep 2010
    1230
    Quote Originally Posted by yaji63 View Post
    If you know where in the program 45 minutes will expire, you could include code that will retract the tool, stop the spindle and then dwell with G04 X600.00 before restarting the spindle and continuing the program.
    Regards,
    Bill
    May 2008
    157
    Thanks Bill, i was thinking on the same lines but i was also wondering whether there is any other method
  1. Replies: 10
    Last Post: 12-21-2013, 09:11 PM
  2. Machine doesnt pause for spindle to stop
    By Lomach in forum LinuxCNC (formerly EMC2)
    Last Post: 07-30-2012, 09:34 PM
  3. Replies: 5
    Last Post: 12-31-2011, 02:29 AM
  4. EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 06:05 PM
