588,496 active members*
4,554 visitors online*
Hybrid View
    Sep 2008
    Slag Removal?
    Simple question: I am fairly new to this whole plasma cutting thing and curious as to what you guys use for slag removal on cut parts? Do I just need to get a needle scaler?
    Jul 2004
    601
    A needle scaler with a chisel tip works about the best.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Mar 2008
    9
    maneric acid works good. mix with water 50/50 in a plastic tub do not use a steel tub in time it will eat through it. also the acid we desolve aluminum!!!!
    Feb 2006
    1260
    If your tip is in good shape, air is clean & speed is just right. You shouldn't have a lot of slag to remove. Sometimes a short length of flat bar works pretty good too. Slide the end of it along the plate perpindicular to the slag banging into it.
    If it works.....Don't fix it!
  1. Tailstock removal
    By em322 in forum Okuma
    Last Post: 12-11-2008, 07:16 PM
  2. Overlay slag at the nozzle cutters.
    By litstamp in forum Waterjet General Topics
    Last Post: 09-05-2008, 08:48 AM
  3. resolver removal
    By will_lewis in forum Servo Motors / Drives
    Last Post: 01-06-2008, 02:32 AM
  4. Spindle removal? :)
    By jinu117 in forum Syil Products
    Last Post: 11-05-2007, 03:54 AM
  5. Vibratory or tumbler for slag?
    By BallisticFab in forum Mass finishing equipment/media/strategies
    Last Post: 03-05-2007, 10:14 PM
