Are you positive they are 3v/krpm?
I have never seen a motor that size with that low a voltage.
In my Aerotech Cat. they show 160v bus volts for that motor, max rpm 2700.
Aerotech make drive for it of course, so does A-M-C. but analogue control.
Al.
Albert E.
The 3V/krpm is the tachometer output spec.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
SwampDonkey,
I believe the model you have is a "1960DC"
Jeff...
but 160 v is not the world as well ,.. how much did that servo cost ?
Gesendet von iPad mit Tapatalk
I have 3, and got a special deal on them. Ive ordered some nice new Heidenhain ERN 471 5000 encoders to replace the odd tach/coders they come with. Something tells me the drives would be a tough combo to find. The plan was to swap the steppers on my Tormach with servos. With Pathpilot being a LinuxCNC interface and the 5i25 card, I could close the loop with a daughter card. I already have linear scales. Im considering totally closing the loop. The Aerotech DC servos will likely be sold to someone with a larger mill that can get some real use out of them.
Unfortunately, these servos are a bit large for this application. They would work, but smaller AC or brushless servos make much more sense. Im curious as to how some 400W panasonic AC servos would do for the X/Y axis.
Make a good spindle motor!
Al.
Albert E.
This one look as a good customer for HP UHU http://www.cnczone.com/forums/uhu-se...-hp-uhu-2.html
If you want to use a linear encoder you must not have backlash or the backlash must be smaller than the resolution of the encoder. Also the mechanical fixation of the encoder must be done with great care to avoid instability. A 5 micron step (20 micron line) is the most simple implementation, because of those big steps the PID will not be very nervous, experience show that it work VERY well .
The Graal will be a linear encoder for the position and a rotary encoder integrated (arduino?) to make a pseudo encoder, to be done....
