We could have yet another discussion comparing the specs of the two machines and still arrive at no particular conclusion. For me the deciding factor between the two machines would be the support, both from the company and from other users.
I can’t speak for Smithy support but from Tormach it is 150%, truly and absolutely spot on, whether it relates to help with specific problems, documentation, ongoing development and improvements, video samples, availability of tooling and accessories, overall professionalism of the organisation etc. etc. etc.
With regard to support from other users then just compare the number and content of relevant posts/ threads on Smithy CNCzone with those on Tormach CNCzone from the beginning of the year, it speaks volumes. Also with regard to software help, Mach3 must be one of the most highly online supported software packages out there, and if they can’t help you Tormach will, as the Mach3 software provided by Tormach is tailored to the Tormach mills.
Oh ya and the machine itself, well you take it out of the box and start using it. It works as advertised, no excitment no dramas. If there should be a fault then you fall back on that 150% support.
Never, ever underestimate the value of top notch support.
Phil
![Smile](images/smilies/smile.png)
