587,272 active members*
4,816 visitors online*
    Jan 2013
    Need help sending files
    Looking for help sending files. I recently have tried sending files to my Haas VF2, using a new 64 bit computer, with windows 7. Gibbscam 2004+, and 2010. Through a USB/Serial adapter. Though I have used this configuration several times in the past, with windows XP, I am having no luck with windows 7. Communication seems fine, through the RS cable. The machine errors out. Errors 405, and 411. incorrect Onnnn block, or missing program between the start %, and end %. Any help would be appreciated.
    Dec 2008
    717
    It looks like you aren't using ethernet...so if you are simply loading programs, why not just stick them on a USB stick or go through the RS232? That is SO simple and you already have it working.
    The manual states this:
    Note: External USB hard drives only work when they are formatted
    as FAT or FAT32. NTFS formatted devices will not work. To find
    out what your devices is formatted as; connect it to your PC,
    right click on the drive in Windows Explorer and select Properties.
    I'm not sure if it applies to external computers but I might tend to assume it does. I don't believe I can load via usb/computer on my 2006 but if your machine is newer look at page 51 of the manual for the instructions.
    Tim
  1. Problems sending files to Prototrak MX2
    By Lugy in forum Dolphin CAD/CAM
    Last Post: 03-03-2016, 05:08 PM
  2. Help sending files via RS232
    By ghansen in forum DNC Problems and Solutions
    Last Post: 12-18-2013, 01:48 PM
  3. HELP SENDING FILES
    By Sierra VF2 in forum GibbsCAM
    Last Post: 01-30-2013, 01:47 AM
  4. sending and receiving files
    By ashro in forum OneCNC
    Last Post: 02-08-2011, 09:04 AM
  5. Sending Program Files
    By Astrocncdept in forum HURCO
    Last Post: 05-09-2009, 01:21 PM
