588,225 active members*
4,379 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > mach3 BOB spindel direction
    Nov 2009
    12
    Hello
    I have the a BOB for mach 3. In the manual there is nothing about the spindel direction. It is a 5 axis board. I need just 4 (X,Y,Z,A). Is it possible to use a pin for the 5 axis?
    Mar 2007
    2083
    Re: mach3 BOB spindel direction
    unless you add another relay to the breakout board
    for example
    this is a dual relay that you could add ,
    Attachment 405446
    the 2 relay board could be controlled by the "step" or "direction"
    outputs from an axis not being used to control a stepper motor
    alternatively a single add on relay could be controlled by pin 16
    the breakout boards onboard relay only provides on/off control of the spindle
    the analogue 0 to 10V DC output being used for speed control
    Attachment 405448
    what type of spindle speed control do you need to control ???
    most VFD manuals show how they can be controlled by 2 switches -
    one for forward and another for reverse
    the switches can be replaced by two relays for CNC control
Name:	CNC to VFD connection.jpg
    John
    Nov 2013
    4603
    do you have any left-hand cutting tools?
    When I started I thought I needed a bi-directional spindle but then never used it. I do have three lefthand drills for trying to get out broken bolts and things
    but I never use them in the mill.
    Craig
    Nov 2009
    12
    Thanks a lot John. I have a syil with a smoked spindel controler. I don't get any spare parts from syil. I have a infranor servo controler and servor motor. That runs with a signal cc aud cl. For the speed I need 0-10V. The BOB is ok for that. I was not shure if I could use a output of a axis which I do not use.
  1. Mach3 G54 Zeroing in Negitive direction
    By CEStanley in forum Benchtop Machines
    Last Post: 05-09-2018, 06:36 PM
  2. Mach3 is moving in the opposite direction
    By maly-miller in forum Mach Mill
    Last Post: 03-04-2014, 03:00 PM
  3. Erratic direction changes in mach3 lathe
    By GF12 in forum Mach Lathe
    Last Post: 02-17-2013, 05:29 PM
  4. Direction output inverted in Mach3 R3.041
    By kreutz in forum Machines running Mach Software
    Last Post: 07-22-2010, 01:18 AM
  5. A3977/Mach3 Direction changes randomly
    By kiltjim in forum Open Source Controller Boards
    Last Post: 12-09-2007, 03:04 AM
