587,936 active members*
2,991 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > HELP! Laser Etch Bare Aluminum then anodize
    Aug 2011
    i have a project to complete and need some help from fellow members here.
    i was task to laser etch an gold anodize aluminum with lettering "do not torque". What is the best possible solution? The parts have not gone to the anodizing shop yet. Can i etch with ceramark on the bare aluminum and then anodize over it?
    Thanks a million
    May 2011
    Laser after the anodizing, letters will turn white.....assuming you have a CO2 and you use the aluminum version of Cermark, all you will get a slight bond and then anodize over the bumps....again assuming the cermark isn't effected by any cleaning done before anodizing.
    Jan 2006
    2985
    I second the laser after suggestion.
    Matt
    Jul 2005
    12177
    Quote Originally Posted by SteveinGB View Post
    .....again assuming the cermark isn't effected by any cleaning done before anodizing.
    The cleaning process may not affect it but the anodizing process itself takes place in concentrated sulphuric acid which probably will affect it.
  1. Making PCB with laser (no chemical etch)
    By RoboticsMD in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-07-2020, 10:25 AM
  2. Laser Etch Bare Aluminum then anodize
    By gstar1988 in forum Hobby Discussion
    Last Post: 08-25-2011, 03:40 PM
  3. Laser Etch Job
    By clembrant in forum Employment Opportunity
    Last Post: 04-08-2008, 07:17 PM
  4. Replies: 6
    Last Post: 12-21-2007, 02:52 AM
  5. how to Anodize aluminum?
    By ezland00 in forum MetalWork Discussion
    Last Post: 02-09-2004, 06:02 AM
