588,414 active members*
5,278 visitors online*
    Feb 2008
    547
    Question Delta 3 phase and Fanuc control
    I've moved to a new shop location and the 3 phase power is delta 3 phase 240 volts. The old shop had "Y" 3 phase 208 - 220 volts. All my other CNC machines have adjustable transformers so I had no problem hooking them up and the manuals machines, of coarse, love it.
    However, my CNC lathe has a Fanuc 0i - T control(1997 machine) and no adjustable transformer. Is anyone out there knowledgeable on if I have a hookup problem or not given going from a 208 - 220 volt source to a 240 volt source? Is anyone out there running this control off of a delta 3 phase 240 volt source? I am reluctant to go forward without knowing for sure it is OK. Steve
    Sep 2008
    33
    The best thing to do would be installing buck boost transformers to get your voltage down to 220.
    If the voltage in your place is steady at 240, you should be fine to run as is. You're still within 10%. Controls that are that finnicky about input voltage usually just generate servo alarms like overvoltage or overcurrent, but nothing catastrophic. They'll just alarm out frequently and need to be reset.
    If it were my shop, I'd just hook it up and try it. If you want to be really safe, install the buck boost transformers first.
    Sep 2007
    371
    Your control is protected, you can hook up to the 240V with no problem. You can work 220V +10%.
    Greg.
    Feb 2008
    547
    Smile Thanks all...
    ...for the input. I am also going to try a call to Fanuc in the morning for input. I would have thought there would be in place something to protect the control as there is with other controls I've used.
    The line voltage by test is very consistant at 241 to 242 at the box and between legs. I would guess that by the time I run the 50 ft of line to the machine I will be at 240 v. I'm not concerned if the machine can protect itself from overvoltage, just from damage.
    I'll pass on what Fanuc says.
    Steve
    Feb 2008
    547
    Smile Update...
    I decided not to hook up to the 240v based on conversations with the service people and a Fanuc applications engineer. The reason is that the considered safe voltage range is based on 208v plus or minus 5%.
    I picked up a used/inspected/ warr. transformer 240 (high) stepped down to 208 (low), 75KVA. It will be here in a week. $625 poorer, but could have been a lot worse.
    Steve
  1. Dynapath Delta 20 CNC control
    By gary098 in forum Uncategorised MetalWorking Machines
    Last Post: 12-13-2012, 04:05 PM
  2. Delta to wye 3 phase
    By StephenSebastia in forum Phase Converters
    Last Post: 07-07-2008, 06:22 PM
  3. lagunmatic with delta 10 control to mach 3
    By madmachinist77 in forum Mach Software (ArtSoft software)
    Last Post: 04-04-2008, 04:27 AM
  4. Hurco BMC20 With Dynapath Delta Control
    By Steve A. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2006, 07:22 PM
  5. Dynapath Delta 20 control
    By Steve A. in forum DNC Problems and Solutions
    Last Post: 08-17-2006, 07:56 PM
